There were several versions of the BV11.
If you can get one of the latest, I’d go for the BV11….in fact personally I’d almost go for the BV11 in any case.
But - as always - it depends on your use case!
This said, the BV14 is a good tv as well…….as long as you don’t expect it to be a SmartTV (which you also should not expect of the BV11). It is said to run more troublefree now than in the beginning.
So, no absolute best recommendation for either of them from me.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
