Assuming that you have a Shape configuration with more than 2 loudspeaker tiles, then all speakers in the array are playing *something* in each of the three modes when you have a two-channel input to the system - and that *something* is full-band in all instances.
This therefore means that it's not only that the woofers are all collaborating on playing the low-frequency bands. So, in "stereo" mode, there's more going on than just a simple 2.1 setup with lots of woofers taking care of the .1 signal.
I don't know if I'd be allowed to reveal more detailed information than this. However, this much would be easy to verify if you're standing close to a Shape by listening closely to each tile in the system.
Cheers
- geoff
I really like the shape too and it's growing on me for consideration to use as rear speakers with a Beovision.
I like that, when you keep the core connected to it that you can use it as a stereo / hi fi system and also in a set up with a BV as rear speakers and it switches between them automatically.
Perfect.
In this situation I wouldn't need to buy 28s (sell 18s), i could keep my 18s as fronts, sell my 3's and use the shape instead of going for the 28s.
Geoff Martin:This therefore means that it's not only that the woofers are all collaborating on playing the low-frequency bands. So, in "stereo" mode, there's more going on than just a simple 2.1 setup with lots of woofers taking care of the .1 signal.[T]his much would be easy to verify if you're standing close to a Shape by listening closely to each tile in the system.
Aussie Michael:I like that, when you keep the core connected to it that you can use it as a stereo / hi fi system and also in a set up with a BV as rear speakers and it switches between them automatically.
BeoFrederic: Aussie Michael: I like that, when you keep the core connected to it that you can use it as a stereo / hi fi system and also in a set up with a BV as rear speakers and it switches between them automatically. As a non-expert, the Shape seems to me to be far-and-away the most flexible system that B&O sells.
For those who are not familiar with this way of using the Beosound Shape please have a look at this video:
https://youtu.be/7xV8RyZAzuM
By the way - this article gives a very good introduction to the BS Shape…..should you be interested:
https://medium.com/the-collaborative-edge/the-insider-story-behind-the-beosound-shape-what-it-takes-to-make-a-ground-breaking-product-d4c4d522de81
BeoFrederic: So I had a chance to listen to a large-ish Shape configuration…perhaps eight speakers… in stereo mode. And yes, I can confirm that all of the speakers seemed to be something, even in stereo mode. Bass was impressive, and the soundstage, which should have been smeary, wasn’t.
If the imaging / soundstage were "smeary", then the "something" that we're doing to distribute the sound to all of the loudspeaker tiles wouldn't be working properly. :-)
Cheers-geoff
