BS Shape in stereo - how many speakers are used?
BeoFrederic
Posts 276
BeoFrederic Posted: Mon, Aug 9 2021 9:56 PM
Is this the behavior of a BeoSound Shape?
When put in *stereo mode* by the app, does the Shape:
a) route left channel signal to the single left-most speaker in the Shape config, while
b) routing right channel signal to the single right-most speaker in the config?
If that’s true, then there’s no good reason (while in stereo mode) to have more than 2 speakers in a configuration. All others speakers are unused in stereo mode. UNLESS:
c) low frequencies (‘bass’) are routed to all remaining speakers?
That would change the game. Increasing the number of speakers, not on the extremities of the configuration, should produce a louder/stronger bass, all things being equal.
Does anyone know?
Geoff Martin
Struer, Denmark
Posts 672
Assuming that you have a Shape configuration with more than 2 loudspeaker tiles, then all speakers in the array are playing *something* in each of the three modes when you have a two-channel input to the system - and that *something* is full-band in all instances.
This therefore means that it's not only that the woofers are all collaborating on playing the low-frequency bands. So, in "stereo" mode, there's more going on than just a simple 2.1 setup with lots of woofers taking care of the .1 signal.
I don't know if I'd be allowed to reveal more detailed information than this. However, this much would be easy to verify if you're standing close to a Shape by listening closely to each tile in the system.
Cheers
- geoff
beolion
Posts 485
beolion replied on Tue, Aug 10 2021 5:54 PM
Indeed interesting. The more I see and read about the Shape the more I like it.
It does unfortunately not fit into our house - right now at least which my wife probably is happy about - but I really like it.
Aussie Michael
Melbourne, AU
Posts 3,730
 I really like the shape too and it's growing on me for consideration to use as rear speakers with a Beovision.
I like that, when you keep the core connected to it that you can use it as a stereo / hi fi system and also in a set up with a BV as rear speakers and it switches between them automatically.
Perfect.
In this situation I wouldn't need to buy 28s (sell 18s), i could keep my 18s as fronts, sell my 3's and use the shape instead of going for the 28s.
BeoFrederic
Posts 276
Geoff Martin:
[T]his much would be easy to verify if you're standing close to a Shape by listening closely to each tile in the system.
Well, I responded to this last night, but my post was eaten.
Thank, Geoff, for the intriguing reply. As luck would have it, I suddenly found myself just yesterday in LA, where there are several company stores. (For the last 1.5 years, I’ve been 600 miles from my nearest store. I must rely on the expertise on Beoworld and FB more than most folks understand.)
So I had a chance to listen to a large-ish Shape configuration…perhaps eight speakers… in stereo mode. And yes, I can confirm that all of the speakers seemed to be something, even in stereo mode. Bass was impressive, and the soundstage, which should have been smeary, wasn’t.
So a little mystery in life may be a good thing.
BeoFrederic
Posts 276
Aussie Michael:
As a non-expert, the Shape seems to me to be far-and-away the most flexible system that B&O sells.
Millemissen
Flensborg, Denmark
Posts 14,680
BeoFrederic:
Aussie Michael:
For those who are not familiar with this way of using the Beosound Shape please have a look at this video:
https://youtu.be/7xV8RyZAzuM
By the way - this article gives a very good introduction to the BS Shape…..should you be interested:
https://medium.com/the-collaborative-edge/the-insider-story-behind-the-beosound-shape-what-it-takes-to-make-a-ground-breaking-product-d4c4d522de81
Geoff Martin
Struer, Denmark
Posts 672
BeoFrederic:
If the imaging / soundstage were "smeary", then the "something" that we're doing to distribute the sound to all of the loudspeaker tiles wouldn't be working properly. :-)
Cheers
-geoff
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
