I have a BeoSystem 4, two BeoSystem 3s, and a BeoVision 10. All are connected to the same sources via an Atlona matrix. Due to the difference in processing times, an echo can be heard among the BeoVision/BeoSystems. Has anyone found any settings to adjust the processing time to eliminate echo?
Maybe the Atlona box (or some Atlona add-on) could solve it? For example, the CLSO-824 has 2 audio "routes", and each route can get its own delay of 0-150 msec set from the front panel. Not sure if this is what you want because you might be forced to use the same route for more than one output, but it's worth a check. (Also in the app, see for example, page 18 of https://atlona.com/pdf/manuals/AT-UHD-CLSO-824.pdf .) Hopefully somebody else will have a B&O-centric answer: dealers who had to deal with two generations of TVs must have asked B&O for help -- they re-sell the Atlona matrix boxes and they are listed in the BV10 configuration menu after all.
kallasr:The Masterlink Delay Box might be an option…. ….just a guess. Ralf
….just a guess.
Ralf
Thanks for the suggestion, but that's not actually the use of the Masterlink Delay Box. The delay box is for adjusting the delay of a source that is being sent via masterlink to another B&O device. That's not the case here. Each TV is playing its own local source.
beojeff:Each TV is playing its own local source.
or do I mis-interprete your question? You're searching for a video/audio delay box, correct?
Like Willie suggested on the one and only BeoTalk Podcast: you can try and play around with the picture pre-sets between normal and game and monitor. beyond that muting the sys4 is the only option
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
