BeoLab 17 and WiSa
This post has 8 Replies | 0 Followers
Poly
Posts 26
Poly Posted: Fri, Aug 27 2021 4:20 PM
Hello,
Are there any WiSa compatible TVs that will work with the BeoLab 17s? Where I can get almost the same integration as with a B&O TV? All I can find is that you have to buy a separate WiSa transmitter for LGs 'WiSa compatible' TVs. I'm not talking about B&O TVs, those are too expensive for me.
Esax
Posts 323
Esax replied on Fri, Aug 27 2021 5:35 PM
The latancy of the beolab 17 is 4,4ms or 1,51m. You need a device that can handle that.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Poly
Posts 26
Poly replied on Sat, Aug 28 2021 1:26 PM
So the Beosound Core is my best bet?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Aug 28 2021 2:51 PM
Poly:
The Core has no Wisa, so you’ll need an external Wisa transmitter in all cases if not integrated in your TV.
Poly
Posts 26
Poly replied on Sat, Aug 28 2021 3:04 PM
Thanks. But I can use the Lab 17s just with the Core right? And then use optical to my TV?
BestSound
Posts 35
BestSound replied on Sat, Oct 30 2021 2:18 AM
Yes you can, I do this with a Sony tv connected with toslink to Beosound Core/Beolab 17
BeoVision Eclipse 65....Front: BeoLab 50....Rear: BeoLab 4000....BeoSound 9000 Mark lll....BeoRemote One BT....BeoSound Core....BeoLab 17....BeoRemote Halo....Apple TV 4K....NAS: Synologi DS218j....Disc Player: OPPO BDP-203....Projector: JVC HD-950....Screen: Stewart StudioTek 100....HDMI management: HDFury Integral
BestSound
Posts 35
BestSound
Posts 35
pig30n
Posts 35
pig30n replied on Sat, Oct 30 2021 6:57 AM
I recommend one of the following setups for your TV:
1. Beosound Core + Beolab Transmitter
this works very good if you have more than 2 speakers (up to 11). I use it myself with 5 speakers with a Samsung TV.
2.  System Audio Stereo Hub
https://system-audio.com/product/stereo-hub/
this is the cheapest option but is only for 2 speakers. You don’t need a Core or Transmitter. It has a very good DAC, HDMI, 3 optical inputs, integrated music services and built in WiSA transmitter. It also has DSP Room Correction from the app.
There’s also a 3rd option with WiSA Soundsend but I heard is very buggy so I don’t recommend.
Cheers!
Page 1 of 1 (9 items) | RSS
