Hello,Are there any WiSa compatible TVs that will work with the BeoLab 17s? Where I can get almost the same integration as with a B&O TV? All I can find is that you have to buy a separate WiSa transmitter for LGs 'WiSa compatible' TVs. I'm not talking about B&O TVs, those are too expensive for me.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
So the Beosound Core is my best bet?
Poly:So the Beosound Core is my best bet?
Thanks. But I can use the Lab 17s just with the Core right? And then use optical to my TV?
Yes you can, I do this with a Sony tv connected with toslink to Beosound Core/Beolab 17
BeoVision Eclipse 65....Front: BeoLab 50....Rear: BeoLab 4000....BeoSound 9000 Mark lll....BeoRemote One BT....BeoSound Core....BeoLab 17....BeoRemote Halo....Apple TV 4K....NAS: Synologi DS218j....Disc Player: OPPO BDP-203....Projector: JVC HD-950....Screen: Stewart StudioTek 100....HDMI management: HDFury Integral
I recommend one of the following setups for your TV:
1. Beosound Core + Beolab Transmitter
this works very good if you have more than 2 speakers (up to 11). I use it myself with 5 speakers with a Samsung TV.
2. System Audio Stereo Hub
https://system-audio.com/product/stereo-hub/
this is the cheapest option but is only for 2 speakers. You don’t need a Core or Transmitter. It has a very good DAC, HDMI, 3 optical inputs, integrated music services and built in WiSA transmitter. It also has DSP Room Correction from the app.
There’s also a 3rd option with WiSA Soundsend but I heard is very buggy so I don’t recommend.
Cheers!
