My beolab 7.1 is dead. Had the technician who repaired my Beovision come and take a look.
He found the coil on the board on the right of the pic was damaged. He bypassed the coil saying that its not really necessary as its mainly used to smooth the electricity?
Then there were problems on the left board and he was unable to repair it saying that my best bet is to replace the entire board. Is it really worth it? I can imagine the cost of a board from B&O to be very, very steep and I also imagine its impossible to get a second hand board from somewhere?
I've really had a bad run lately and cannot afford to continue forking out money for repairs. Perhaps its better just to leave it or dump it?
Ben
Can anyone tell me if there is supposed to be an LED light at the back of the Beolab when its switched on?
Please note mine is the first version of this speaker.
kammeri:There is no LED on the 7.1. Regards!
Regards!
The LED is in the rear of the BeoLab7.1 where the sockets are. There is a small rubber bung that you have to remove to see the LED.
Regards
Opman
Thanks Opman .....I found the LED and its also dead...absolutely nothing.
The short was created by a lizard on the board on the left...it got fried and burnt part of the board away and probable other parts of it.
I've contacted 2 B&O agents for a price on a replacement board......still waiting for a reply. Very frustrating.
Bensa just pay the lizards the "protection money " :-)
For anyone that is interested....a new chassis for the Beoab is R30 000.00 which is about 2500 pounds. Luckily I was sitting down. So that puts in end to that!!
@Valve...any lizard that comes near my house has a death wish and it won't be death by B&O either!!!
BenSA:a new chassis for the Beoab is R30 000.00 which is about 2500 pounds
Pre-loved is the way to go.
Would your insurance cover your lizard damage ?I remember you had a good experience with your insurers before.
Yes I did have an extremely good experience with my insurers......not sure they cover lizard damage but I'll give it a bash!!!
valve1:Bensa just pay the lizards the "protection money " :-)
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Hi BenSa
Do you have some parts working? I'm interested in one filter
Hi Eugenio
My Beovision was damaged by lightening so the insurance replaced it with a Beovision 11 and they took the old Beovision away with the stand and the Beolab I'm afraid. So unfortunately I can't help you with parts otherwise I would have been happy to.
