Help Penta II
This post has 3 Replies | 0 Followers
Andrew
Frinton, UK
Posts 917
Andrew Posted: Thu, Feb 21 2013 6:30 PM
Hi
I had a recent power on/off problem with the mains and it fluctuated, now one of my Penta's is not working, no lights or anything. I checked the fuse in the plug and that's fine - is there an internal fuse. I looked in the manual but no mention of one. Do I have to remove the amplifier in the base to find it - or is it the end of my beloved Penta?
As ever, any help would be much appreciated.
kammeri
Posts 49
kammeri replied on Thu, Feb 21 2013 7:39 PM
ajames:
Hi
You have lay the speaker gently on the floor and remove a single panel from the bottom of the amplifier (fixed by a single philips head screw). Remove the PL cable in order to remove the panel (and the mains naturally).
Beneath you will find two different fuses. One is for the display and the other is for the amplifier. If I recall correct the amplifier fuse is 2A. The colour code on it points to a quick burning fuse.
Regards!
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Feb 22 2013 9:37 AM
Hi Kammeri
Just a quick update, I did as you said, and hey presto, all working again - very happy and releived.
A quick thanks also to the administrators and everyone that keeps this site up and running, it is so good to have help and advice on hand when needed.
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Feb 22 2013 9:38 AM
Hi Kammeri
Thanka again
Page 1 of 1 (4 items) | RSS
