Moment headphones
This post has 18 Replies | 2 Followers
Andrewharvey
Posts 37
Andrewharvey Posted: Sun, Oct 3 2021 8:49 PM
Hia beginner question regarding B&O Moment.
How do I connect headphones either wired or Bluetooth?
I'm sure I should know....but I don't
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Oct 4 2021 8:21 AM
To connect over Bluetooth: https://support.bang-olufsen.com/hc/en-us/articles/360054860171-Beosound-Moment-Bluetooth-connectivity
I had the Moment for some time but cannot remember if it had a socket for wired connection. Think not.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Oct 4 2021 1:23 PM
The Moment BT is to connect a music (IN) source not a headphone (OUT)
Regarding the sound output from a Moment, the only ways are Powerlink (wired or wireless) and NL to another B&O NL product. How these outputs could be used to connect device supporting headphones requires some research
seethroughyou
UK
Posts 999
Take cover off the back and BT activates and is discoverable on your mobile device.
No headphone out on Moment.
You can steam music FROM your mobile device TO the Moment. Hope that helps.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Oct 4 2021 4:13 PM
mbolo01:
Thanks. My bad. I thought Moment could connect headphones over BT.
Andrewharvey
Posts 37
So no headphones on a B&O? That seems incredible
Andrewharvey
Posts 37
andybandy
Posts 164
Why is it importent for people to have headphone connection on a streaming product like moment.
if you will Play music on headphone you only streem your music on your headphone and us your phone or tablet.. deezer and tunein can be played.
its not like in the old days When we want to Play a CD and LP from the music system, you cannot only take your phone and Play to your headphone. So thats time it makes sense to have a headphone out. But not on a streaming product.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Oct 5 2021 12:48 AM
andybandy:
Why is it important for people to have headphone connection on a streaming product like moment.
Because some people live in flats, apartments, listen late at night or have small children - and they'd like to listen to their streaming music through headphones instead of Loudspeakers?
It's a fairly basic 'ask' in my opinion!
Lee
seethroughyou
UK
Posts 999
I know this isn’t what you were hoping for but you could get an RJ45 cable to RCA adapter from Steve at Sounds Heavenly and then connect a headphone amp.
A dedicated headphone amp would deliver a phenomenal sound to your headphones.
Andrewharvey
Posts 37
I have both a turntable and CD player connected to my moment.
seethroughyou
UK
Posts 999
Use a switch and connect them to the headphone amp instead.
Andrewharvey
Posts 37
Can you please explain connections.
Headphone amp into switch output of switch connects to....?
Andrewharvey
Posts 37
seethroughyou
UK
Posts 999
1. What is your current setup and how is it all connected?
2. Forgive me, why did you buy a Moment without checking what its capability and connections were first?
Andrewharvey
Posts 37
1) i have a RCA switch connected to the input in the moment. The switch has four ports turntable, CD, Chromecast and spare.
2) i have had the moment a while and my needs have changed. Recently got back into vinyl and so have a great setup...wanted to listen occasionally through headphones
The cable workshop, Leics, UK
Posts 2,165
Whilst a wired connection from a Moment to headphones isn't a popular request, I certainly do get asked for this on occasion and I have a cable to make this possible:-
https://soundsheavenly.com/televisions/32-389-headphone-adapter-for-beoplay-v1-beovision-1112avant-rj45-powerlink-to-minijack.html#/9-length-18m
As Moment only has a single volume control, please note that you would need to turn off the power to any speakers that are connected if you only wish the headphones to be heard (ie. you can't separately adjust the headphone and speaker volumes without adding extra hardware).
Hope this helps.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Oct 11 2021 7:47 PM
Steve at Sounds Heavenly:
This assumes the OP speakers are not wired to the Moment. We don’t know yet his setup on this front.
Posts 2,165
Hi mbolo01,
My assumption above was that there is at least one RJ45 Powerlink socket free on the Moment.  I did mention in my reply above that if speakers are connected, they would need to be powered off to allow listening on headphones only.
Hope this helps.
Steve.
Page 1 of 1 (19 items) | RSS
DigiCert Secured Site Seal
