Hia beginner question regarding B&O Moment.
How do I connect headphones either wired or Bluetooth?
I'm sure I should know....but I don't
To connect over Bluetooth: https://support.bang-olufsen.com/hc/en-us/articles/360054860171-Beosound-Moment-Bluetooth-connectivity
I had the Moment for some time but cannot remember if it had a socket for wired connection. Think not.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
mbolo01:The Moment BT is to connect a music (IN) source not a headphone (OUT)
Thanks. My bad. I thought Moment could connect headphones over BT.
So no headphones on a B&O? That seems incredible
Why is it importent for people to have headphone connection on a streaming product like moment.
if you will Play music on headphone you only streem your music on your headphone and us your phone or tablet.. deezer and tunein can be played. its not like in the old days When we want to Play a CD and LP from the music system, you cannot only take your phone and Play to your headphone. So thats time it makes sense to have a headphone out. But not on a streaming product.
andybandy: Why is it important for people to have headphone connection on a streaming product like moment.
Because some people live in flats, apartments, listen late at night or have small children - and they'd like to listen to their streaming music through headphones instead of Loudspeakers?
It's a fairly basic 'ask' in my opinion!
Lee
I have both a turntable and CD player connected to my moment.
Can you please explain connections.
Headphone amp into switch output of switch connects to....?
1) i have a RCA switch connected to the input in the moment. The switch has four ports turntable, CD, Chromecast and spare.
2) i have had the moment a while and my needs have changed. Recently got back into vinyl and so have a great setup...wanted to listen occasionally through headphones
Whilst a wired connection from a Moment to headphones isn't a popular request, I certainly do get asked for this on occasion and I have a cable to make this possible:-
https://soundsheavenly.com/televisions/32-389-headphone-adapter-for-beoplay-v1-beovision-1112avant-rj45-powerlink-to-minijack.html#/9-length-18m
As Moment only has a single volume control, please note that you would need to turn off the power to any speakers that are connected if you only wish the headphones to be heard (ie. you can't separately adjust the headphone and speaker volumes without adding extra hardware).
Hope this helps.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Steve at Sounds Heavenly:I certainly do get asked for this on occasion and I have a cable to make this possible
Hi mbolo01,
My assumption above was that there is at least one RJ45 Powerlink socket free on the Moment. I did mention in my reply above that if speakers are connected, they would need to be powered off to allow listening on headphones only.
