I have upgraded my B&O app to use the alarm function on my Beosound level. Nothing appears on the app to add this function. Do I have to reload the Beosound level to access this function
Regards Stewart
I asked the same question a few days ago in the BEOSOUND 1 VS LEVEL thread and no one knows, unfortunately. I also submitted an inquiry to B&O through the app support. No response yet but I suggest you do the same so we get some critical mass behind the issue! :)
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I had the same thought--I wondered if the device firmware must be updated as well.
We shall wait and see, I guess. But... yes, confusing messaging if this turns out to be the case.
