does anyone have a copy of eclipse tv mk1 gen please?
A
oops i meant manual
thanks but you cannot download it, which seems crazy?
tantricman: thanks but you cannot download it, which seems crazy?
No, it is a web manual…..which makes it much easier to make changes, if/when there are updates.
Why would you want a downloadable manual?
Millemissen:No, it is a web manual…..which makes it much easier to make changes, if/when there are updates. Why would you want a downloadable manual? MM There is a tv - and there is a BV.
Sure, some times they do disappear.
Actually the Wall bracket Guide is the only one missing in the documents about the V1 on the current support site.
On the other side - B&O does offer a lot of the older manual there.
And no said....actually there is a way to 'download' the manual.
It is a bit of work - besides I would not recommend it, because of the changes that may appear later (with the Wall bracket it was different - not much to change there).
We must face it - online/web manuals is the way to go for products, that most likely will become updates and therefore need changes in the manual.
The way to do it is: to open each page of the manual in the internet browser on your PC/Mac, go look for the export function that your browser might offer, choose 'export as PDF' or alike, name the file and save it.
