eclipse tv manual
This post has 6 Replies | 2 Followers
tantricman
Posts 9
tantricman Posted: Sat, Oct 30 2021 1:01 PM
does anyone have a copy of eclipse tv mk1 gen please?
A
tantricman
Posts 9
oops i meant manual
lawrencejmcook
Posts 742
All on the official B&O website: https://support.bang-olufsen.com/hc/en-us/articles/360041518952-Beovision-Eclipse
tantricman
Posts 9
thanks but  you cannot download it, which seems crazy?
Millemissen
Flensborg, Denmark
Posts 14,680
tantricman:
No, it is a web manual…..which makes it much easier to make changes, if/when there are updates.
Why would you want a downloadable manual?
lawrencejmcook
Posts 742
Millemissen:
I’ll let tantricman answer for himself, but B&O sometimes takes down manuals. A Beoworld member was looking for the BeoPlay V1 wall bracket manual. B&O has taken it off their website, but fortunately I had downloaded it, and I was able to share it with Keith for the Beoworld library.
Millemissen
Flensborg, Denmark
Posts 14,680
Sure, some times they do disappear.
Actually the Wall bracket Guide is the only one missing in the documents about the V1 on the current support site.
On the other side - B&O does offer a lot of the older manual there.
And no said....actually there is a way to 'download' the manual.
It is a bit of work - besides I would not recommend it, because of the changes that may appear later (with the Wall bracket it was different - not much to change there).
We must face it - online/web manuals is the way to go for products, that most likely will become updates and therefore need changes in the manual.
The way to do it is: to open each page of the manual in the internet browser on your PC/Mac, go look for the export function that your browser might offer, choose 'export as PDF' or alike, name the file and save it.
Page 1 of 1 (7 items) | RSS
