Beovision 4-50 Type 9049
zapdady
La Crescenta
Posts 26
zapdady Posted: Sat, Oct 30 2021 5:33 PM
Can anyone point me in the right direction to be able to find parts for my Beovision 4-50 Type 9049?
I am looking for the IR (9 pin serial) card that is located in slot 3 of my TV. With-out this card I can not connect to my Beosystem 3..
Thanks to anyone for help
John McIntyre
(zapdady)
Beouser66
Posts 47
Beouser66 replied on Sun, Oct 31 2021 8:19 AM
its obsolete, maybe it can be repaired?
zapdady
La Crescenta
Posts 26
zapdady replied on Sun, Oct 31 2021 6:46 PM
To be clear, Nothing is broken on my Beovision 4-50 that needs to be repaired, I am trying to find the missing IR 9 pin serial card to be able to interface with my Beosystem 3 unit.
lawrencejmcook
Posts 742
zapdady:
In the U.K. the BV4-50 is very cheap on the usual site. It may be easier to obtain the part this way.
Lawrence
zapdady
La Crescenta
Posts 26
zapdady replied on Sun, Oct 31 2021 7:46 PM
Thanks Lawrence,
When you say usual site, are you refering to eBay? If not please point me to sites that I could explore.
Beouser66
Posts 47
Beouser66 replied on Sun, Oct 31 2021 8:47 PM
i don't understand what you say..
if you missing the 9pin serial card on your bv4-50 the bv4 50 is faulty..
b&o have never sold a bv4-50 without this module!
zapdady
La Crescenta
Posts 26
zapdady replied on Sun, Oct 31 2021 9:12 PM
Look for yourself. Slot 3 is empty
zapdady
La Crescenta
Posts 26
Look for yourself
lawrencejmcook
Posts 742
zapdady:
Thanks Lawrence,
Yes, I meant eBay. I’ve seen them for 50 GBP. Also, might a BV9-50 have the part you need? They’ve failed to sell at just a few hundred GBP (also eBay).
Page 1 of 1 (9 items) | RSS
