Can anyone point me in the right direction to be able to find parts for my Beovision 4-50 Type 9049?
I am looking for the IR (9 pin serial) card that is located in slot 3 of my TV. With-out this card I can not connect to my Beosystem 3..
Thanks to anyone for help
John McIntyre
(zapdady)
its obsolete, maybe it can be repaired?
To be clear, Nothing is broken on my Beovision 4-50 that needs to be repaired, I am trying to find the missing IR 9 pin serial card to be able to interface with my Beosystem 3 unit.
zapdady:To be clear, Nothing is broken on my Beovision 4-50 that needs to be repaired, I am trying to find the missing IR 9 pin serial card to be able to interface with my Beosystem 3 unit.
Thanks Lawrence,
When you say usual site, are you refering to eBay? If not please point me to sites that I could explore.
i don't understand what you say..
if you missing the 9pin serial card on your bv4-50 the bv4 50 is faulty..
b&o have never sold a bv4-50 without this module!
Look for yourself. Slot 3 is empty
Look for yourself
zapdady:Thanks Lawrence, When you say usual site, are you refering to eBay? If not please point me to sites that I could explore.
