I have a Beosound 5 and Beolab 5 connected to a Beovision 7-55 in the same room.
There is two options in feeding the Labs 5 with sound from the Beosound 5:
1. Thru Masterlink from Beomaster 5 to Beovision 7-55 and powerlink from the TV to Labs 5.
2. Digital-coax-cable from Beomaster 5 directly to Beolab 5, and still Powerlink from the TV to Labs 5 and Masterlink between the Beosound 5 and the TV. I have to re-name the source from N.MUSIC to CD, otherwise the Labs 5 digitalconnection will not work.
I have tested this two alternative connection-possibilities and it sounds different.
Alternativ 1: The sound is more "compact" with a good bass-response and the treble is rather smooth.
Alternativ 2: There is more "air" in the sound, and the treble is more brittle and if you listen to a song with female voices you have to put down the volume a bit to not hurt your ears. The bass-response is a little bit worse than alternativ 1. The total sound-picture is more wide and deep with this alternative.
Have anyone tried these to ways of connecting the Beosound 5 to labs5? I have tested alot of songs and it is very hard to determine which way gives the best sound.
Please any advice (especially if you have tried this two ways of connection your self).
RegardsMartin Stroem
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
I have in the sitting room BV7, BM5 / BS5, BS9000.Loudspeaker BL5, BL3, BL7-4. All loudspeakers go by power link directly to the BV7. Digitally goes, in addition, from BS9000 to BL5. Am contented with the sound.
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
Well connecting them with the SPDIF cable will produce the "best" sound. However, tastes vary if you like the ML sound better (which will be a modified source) then use that one. But in using the ML there's unnecessary D/A conversions, and IMHO you'll lose some of the data.
Too long to list....
Hi Martin,
Will you explain this a little more, as I have problems in making the digital connection work.
I have the same setup except for a BV7-40 with Blu-ray and a BEO6.
Do you press CD in order to select music from the Beosound and will it not conflict with the DVD in the BV7?
Regards Ole
Hi OKA,
If you connect the SPDIF-cable between the BM5 and LABS 5 and another spidf-cable between the two labs 5, then the digitalconnectin will work perfect. BUT: You must re-name the source in the Beosound 5 from N.MUSIC to CD. You do this in the setup-menu when you choose "roles". When you have re-named the source from N.MUSIC to CD, then you press CD on your remote and the Beosound 5 will play and the sound will go thru the digital spdif-cable instead of masterlink-cable.
It will Not conflict with the DVD in the BV7. DVD is a video-source and CD is an audio-source.
You must have a CD-button in your BEO6-remote, otherwise you have to re-configurate the remote.
You will notice a much better soundstage with the digital connection.
RegardsMartin
Yes, it is working when setup as CD as you described.
My problem now is that the 2-way music selection on BEO6 does not work anymore. Apparently Beosund5 shall be named N.MUSIC for it to work.
But anyway, it was a step forward. Thank you.
Hi Oka, you have to re-program the Beo6 if you want the 2-Way communication to work. You must change the n.music Button to CD button. My Beo6 works perfekt with 2-Way communication when using the Cd-command in order to use spdif from BM5 to LABS5.
Of course you were right again, so now everything is working well with the SPDIF connection.
Thank you again.
