Guys I have just acquired a pair of M75s. One of the front covers is hanging by only two of the dowels as the others were broken or missing.
Any suggestions as to where I can buy replacements? Ive just bought some off eBay (Monacor Front Dowels for Speakers) that I thought would do the job but they are a different size.
Thanks in advance (they sound fantastic connected to my Beocenter 7002.
Difficult to find fitting dowels! Has been asked here before but I've never seen a perfect solution.
Some glue or screw wall plugs normally used for screws in place. I've also read about someone using sticky magnets.
I would love a good solution (3d print? reproduction?) So I'll keep an eye on this thread.
Hello there. I too had this problem a few years ago. They are quite delicate and snap easily. What I did was just replace them all with those small discs of velcro, it works fine.
Hey now why didnt I think of that. Great solution - many thanks - will do! I even have some velcro spots about somewhere..............
These?
https://beoparts.com/2014/07/16/beovox-front-grill-baffle-locking-pin/
