Stuck in phono mode Beomaster 1900
2amp
Posts 2
2amp Posted: Tue, Feb 26 2013 1:14 AM
Greetings all.  Total beo virgin here.
Just picked up my first.  A  Beomaster 1900.  All was swell until powered up this morning.  Standby came on.  Pushed FM 5.  Phono light came on in addition to FM 5.
Unit was now in phono mode.
Every other mode pushed came on but phono light remained on and kept unit in phono mode.
Have shut down and restarted may times.  Always same result.
Your adult supervision would be greatly appreciated.
Much thanks in advance.
Alan
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Feb 26 2013 6:44 AM
Welcome to Beoworld !
Could be several things. Could be as simple as the transistor related to the Phono sensitouch pad, could also be ripple on
the low voltage power supply from dried out capacitors and/or a defective rectifier and it's not rare to see wrong wattage lamps causing
this - and many other similar - problems. Finally, the Beomaster could've been put together incorrectly, it's not the easiest thing if you don't
know how.
Capacitor - and lamp kits are available, as are new rectifiers.
2amp
Posts 2
2amp replied on Tue, Feb 26 2013 11:26 AM
Thanks much Martin.  Will dig in.
If you are a religious man...let the prayerful wailing begin.
Alan
Søren Mexico
Mexico City
Posts 6,411
2amp:
Alan
No prayers or wailing will help you, only hard workBig Smile, I did my BM 2400 with Martins kits, get the trimpots too, and check the Treble Bass and Balance sliders when the BM is open.
Page 1 of 1 (4 items) | RSS
