Core software updated -- TuneIn favorites deleted/lost
This post has 32 Replies | 0 Followers
Curly
FL, USA
Posts 366
Curly Posted: Fri, Dec 3 2021 4:12 PM
My Core updated to the software released a week or so ago and while B&O Radio has been added, my TuneIn favorites are no longer listed.
If I click the "radio button" ((o)) in the bottom right corner of the B&O app, I am taken to a screen with "B&O Radio" and "TuneIn" at the top. When I tap "TuneIn", I get a search bar and but none of my favorite stations appear. "No results found" appears two or three times underneath. That's it.
I have logged out and in of TuneIn through the B&O app. No change.
When I search for a station I favorited and the search result is shown, if I click "..." next to the radio station, it shows the heart icon dark and gives me the option to REMOVE FROM FAVORITES.
So clearly, my favorite stations are still in the TuneIn brain somewhere. But there is no favorites list within the B&O app anywhere. So I can't actually call up a TuneIn station without searching for it.
Might anyone (a) have any suggestions?; or (b) be experiencing the same thing?
Cheers.
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 3 2021 4:40 PM
I will check my Core when I get home and see if the update is available and if so install and see what happens.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Dec 3 2021 4:54 PM
It’s an application issue that has been fixed in the latest beta
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 3 2021 6:00 PM
No update on my Core yet.
Millemissen
Flensborg, Denmark
Posts 14,680
@Curly
Which version of the Bang & Olufsen app are you using - a regular or the beta?
If you have more devices with the app (beta/regular versions), please try all of these.
Curly
FL, USA
Posts 366
Curly replied on Fri, Dec 3 2021 8:03 PM
MM, I am using the latest iOS version of the app: 3.20.0.41064
I am not on the beta. :)
Curly
FL, USA
Posts 366
Curly replied on Fri, Dec 3 2021 8:06 PM
Ahhh!!
3.20.1 was just released this afternoon! I have updated and it has fixed the issue--I now see all my favorites again.
WHEW! Great news. Thanks everyone for your help!
I'm going to go play with my new, rattling Halo now. ;)
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 3 2021 8:30 PM
What is the software version on your Core?
Curly
FL, USA
Posts 366
Curly replied on Fri, Dec 3 2021 9:07 PM
1.12.47460, Raz.
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 3 2021 9:26 PM
Thanks! I have the same version and I see B and O radio in the app, but am unable to start any stations in B and O radio. Any suggestions?
Curly
FL, USA
Posts 366
Curly replied on Fri, Dec 3 2021 9:28 PM
Try updating the B&O app itself. A new version of the iOS app was released today (to me, anyway). It fixed it for me.
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 3 2021 9:31 PM
I did that earlier. App says function not supported by selected product. Should B and O radio be working? (Also responded to your private message)
Curly
FL, USA
Posts 366
Curly replied on Fri, Dec 3 2021 9:35 PM
I'll check in a little bit--I see B&O Radio in my Core but I haven't actually tried to launch a station. I've only tried TuneIn.
I'll try B&O Radio and check back.
Also responded to your PM again.
Curly
FL, USA
Posts 366
Curly replied on Fri, Dec 3 2021 10:04 PM
Update:
On my Core, I can see B&O Radio station favorites from my Level. But if I try to play one, I receive an ACTION NOT SUPPORTED ON THIS DEVICE error.
So I can't actually play B&O radio stations on my Core (unless, maybe, I start it on the Level and join the Core to it via multiroom).
BeoFrederic
Posts 276
My Core/Shape is running 1.12.47460; however B&O Radio is not offered as a service in either Bang & Olufsen app or BeoTool. I’ve checked the App Store and I’m running current versions. I can see Spotify, Tune-In, but no B&O Radio.
My hypothesis that there’s a licensing problem for users in the U.S. is shot down by the fact that both Curly and Razlaw are, I infer, located in the States. Hmmm……
Not the end of the world. More curious than needful at this point.
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 4 2021 11:44 PM
BeoFrederic:
Yes, in the States. My thought has been the app has been updated to include B and O radio but that the Core has not yet been updated?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 5 2021 5:24 AM
mbolo01:
B&o Radio = for B&o Control link (Mozart) devices
TuneIn = for Netlink devices
and theTuneIn issue has been fixed in the beta app as mbolo01 said before. If B&o Radio will come to NL devices = ???
My Shape has the same sw version since the 1st November (EU).
Millemissen
Flensborg, Denmark
Posts 14,680
My updated beta app shows exactly the same for all my devices (NL audio and NL tv), when I tick the Radio button below.
However, I can’t choose the B&O Radio on my audio devices and I can’t choose the TuneIn on the BV’s…….and the showed B&O Radio stations are not those that I have in my Netradio function on the BV’s.
The beta is still a mess!!!
But - at least - now I can choose my favourites on the audio devices again.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 5 2021 10:05 AM
Millemissen:
it is beta, not a mess.
Choose radio button on the app with the Balance actual, the B&o Radio tab is set.
Choose radio button on the app with the Beosound 35 actual, the TuneIn is set.
Choose a radio setting which is not compatible with the device, a notification  is shown.
Millemissen
Flensborg, Denmark
Posts 14,680
@Carolpa
Yes, sure I know it is a beta - but still they need to know that it is a mess.
The app should not show B&O Radio at all, if that is not supported by the choosen device and vice versa.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 5 2021 10:42 AM
Millemissen:
agree
but did you already report it in Testflight? Otherwise why use a beta app.
I just did and asked to make one of the tabs invisible!
Millemissen
Flensborg, Denmark
Posts 14,680
Well actually - I tried to a couple of days ago Unsure
I wanted to add a second picture there to illustrate my point of view.
However, that is not possible….and it resulted in my (rather long) posting going into Nirvana.
And at that time I hadn’t the time and muse to start all over again.
Glad you did it - and succeeeded Smile
Millemissen
Flensborg, Denmark
Posts 14,680
Sandyb
Posts 2,186
Sandyb replied on Sun, Dec 5 2021 3:33 PM
B&O Radio is coming to quite a few NL devices relatively soon
The support link someone posted last week shows the table of functionality across devices from what I remember
But given the imminence of B&O Radio to older devices, I can’t see them changing the app ahead of that update
Millemissen
Flensborg, Denmark
Posts 14,680
SirPump
Posts 14
SirPump replied on Mon, Dec 6 2021 8:26 PM
Wat are the advantages of B&O Radio over TuneIn?
Sandyb
Posts 2,186
Sandyb replied on Mon, Dec 6 2021 8:40 PM
good question!
Yes, TuneIn and the BBC have divorced for UK listeners, though BBC stations remain on my A9 / BS2 due to the limbo / standstill agreement for continued service for some older devices. That situation may not continue though, and a full rollout of B&O Radio for older devices may lead to TuneIn removing BBC for those devices.
Besides that, I'm not sure the reasons for the move.
There may be good reasons though that others can provide?
Curly
FL, USA
Posts 366
Curly replied on Mon, Dec 6 2021 8:43 PM
In the USA, I don't know what the advantages of TuneIn over B&O Radio are, or vice versa. I don't know why anyone would want access to one over the other at all.
laseralex
Posts 240
TuneIn still has the advantage of being able to add a custom URL, something that B&O radio doesn't currently have, and as far as I can tell is not on the future features list.
For example, I have a subscription to Jazzradio.com.  With TuneIn I can add a custom URL to allow access to their streams from my B&O equipment.  With B&O Radio I can't.  For example, https://www.jazzradio.com/mellowpianojazz isn't available through B&O Radio, but I can easily add it through TuneIn.
I think the advantage of B&O Radio is that they can deals to work with BBC and perhaps other stations which can't be accessed through TuneIn due to licensing issues.  For example, in the USA the giant radio conglomerate Audacy (formerly Entercom) removed all their stations from TuneIn a few years ago, telling listeners to download the radio.com app for listening.  When they did that, all their stations disappeared from TuneIn on my B&O gear.  (I was able to add custom URLS through the TuneIn app to recover the stations through a little backdoor.)  With B&O Radio they presumably make deals to allow access to all these services.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
lawrencejmcook
Posts 742
SirPump:
With B&O Radio I can get BBC radio stations in the U.K…
… and NRK Jazz!! 😃
These aren’t available with TuneIn.
Sandyb
Posts 2,186
Sandyb replied on Wed, Dec 8 2021 9:15 AM
lawrencejmcook:
… and NRK Jazz!! 😃
I still get BBC via Tunein on my A9 and BS2 in the UK
lawrencejmcook
Posts 742
I don’t get them on my A6
chucky
Posts 331
chucky replied on Sat, Dec 11 2021 9:27 AM
Ok I have serious issues with the BLI. If I start up the B&O app the BLI does not start up or it takes forever. I selected multipele sources pres play on Deezer and then opened the BLI app. No response.
If I start up the BLI and then the app it was ok. But yesterday on multiroom also in the BLI volume in multiple sources there was a lag or delay.
Can somebody with a BLI please check. So first B&O app start music and than startup BLI.
Thanks chucky
Page 1 of 1 (33 items) | RSS
DigiCert Secured Site Seal
