Hello all
Have anyone of you installed the Harmony on the stand by yourselve? I consider myself handy enough to do it, just asking about the configuration and cable management
Would be happy if someone can share their experience
Thanks in advance
Carlo
Go easy! Sounds like a big ask to me.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
There is an internal (although publicly available) video on YouTube from B&O serving as an installation how-to. I can't find it at the moment but I'm sure someone handier than I will be able to.
I actually think it looks fun and don't think it looks like a big job! Does anyone think it was really too difficult to do on your own? @Mikipedia installed his own...
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Thanks for the answers above
Another question came up and therefore I changed the title.
How can a headphone (Beoplay HX / H95) connected to the Harmony? There is no Headphone and digital out - only Powerlink? Maybe Steve from Sounds Heavenly has an answer here....
The headphone you need to connect with Bluetooth with the tv.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I did both on my own, first floor stand, than later wall bracket. Video from B&O very helpful, without that would not have done it. Just to expensive stuff to potentially damage it.
As Mikipidia said, it is very heavy! Floor stand is much easier to handle as the wall bracket. just more space to work. My respect to Sig to do the job without a second person, for me it sounds almost impossible :-)
I guess next time I would ask my dealer to do the job...I am getting older :-)
