Checking the NL/ML converter manual, it seems that all NL devices must be on the same subnet. Anyone know if there is a way to bridge this? I’m keen to have a larger subnet say /16 instead of /24.
Eclipse 65V1-32Beosound M5Essence MK2BLI
Yes, already have that done. Didn’t make a difference. Outside the subnet, I can discover and switch on other sources, but the stream doesn’t get through. Would be good to know what ports are being used - then I could see about finding a way through.
UDP 5353
TCP 5222
TCP 8080
UDP 3319
UDP 3320
UDP 1234
UDP 1235
TCP 1234
Thanks - that did it - now I've got streams across subnets!
