NL across subnets.
This post has 4 Replies | 2 Followers
frog
Camberley UK
Posts 624
frog Posted: Mon, Dec 20 2021 9:34 PM
Checking the NL/ML converter manual, it seems that all NL devices must be on the same subnet. Anyone know if there is a way to bridge this? I’m keen to have a larger subnet say /16 instead of /24.
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Mon, Dec 20 2021 10:24 PM
Allow broadcast traffic and multicast between subnets maybe?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
frog
Camberley UK
Posts 624
frog replied on Mon, Dec 20 2021 10:38 PM
Yes, already have that done. Didn’t make a difference. Outside the subnet, I can discover and switch on other sources, but the stream doesn’t get through. Would be good to know what ports are being used - then I could see about finding a way through.
christiank
Posts 64
UDP 5353
TCP 5222
TCP 8080
UDP 3319
UDP 3320
UDP 1234
UDP 1235
TCP 1234
frog
Camberley UK
Posts 624
frog replied on Tue, Dec 21 2021 2:12 PM
Thanks - that did it - now I've got streams across subnets!
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
