Could anyone shed some light on where this part i'm holding in the photo goes on beomaster 1600 (1980s)
Don't know if its part of the beomaster 1600, i found it in the beomaster box, i think someone might have tried to service it sometime ago .
If it is part of the beomaster could anyone help out with some photos.
Regards all
marc
Yes, it goes on the clutch mech.The three holes fit over the three white protruding tabs of the clutch operator arms.This part releases the volume clutch when any of the trebele/bass/balance controls are pressed.It's held in place by two round hairpin-like springs, one each end, and a more normal third spring keepsit in a position of constant activating the volume control until one of the tonecontrol buttons are pressed.The way you hold it in the photo is practically the same way it sits inside when the Beomaster is closed.
Like this :
I think, the red thing is a piece of shrink tubing. Probably put there because the slotted end ofthe black plastic wheel shaft broke off.Not something I did.
Can you tell if the spring puts enough tension on the volume clutch ?Does the volume clutch release when a tonecontrol button is pressed ?Does the toncontrol clutches put enough tension on their respective clutches ?In some cases, it can be necessary to put a piece of paper or plasticard or similar onthe head of the operating arms to compensate for wear.
The most common problem is the rubber clutch washers slipping.They sit inside the see through clutch mechanism housing and they age and wearand lose friction. Maybe you can tell if that is the problem ?Reproduction rubber clutch washers are available (from me).
The rubber clutch washers seem to be slipping as you say, what to you mean by teel
also the tonecontrol clutches don't seem to have enough tension as you say
I bought a couple sets of Dillen's replacement clutch washers. They worked and restored full control to the Beomaster.
