The wall mounted Halo is drop dead gorgeous. I’m curious—how did you install it? Did you already have electrical and/or Ethernet running to that spot on the wall?
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
chucky:How do I change order in the Halo,
Carolpa:Chose the button and drag it to the preferred position (in the above setting page).
Curly:The wall mounted Halo is drop dead gorgeous. I’m curious—how did you install it? Did you already have electrical and/or Ethernet running to that spot on the wall? Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote Previously: BeoSound 1 non-GVA
chucky:Did you have also problems with getting it in the app and updating?
A pity that the coloured icons do not show up on the Halo. I tried to change the text colour. No success, but strangely the used Lua command was without errors, accepted.
chucky:Did anyone get colors on the Halo? I remember seeing it somewhere, maybe Khimo can make some fonds?
Carolpa: chucky:Did anyone get colors on the Halo? I remember seeing it somewhere, maybe Khimo can make some fonds?There are coloured dots on the Halo if it is set for Beovision 11, Harmony,........... representing the coloured keys of a BR1.
I'm wondering if B&O might have another surprise for us down the road. Comparing the screen size and resolution specs of the Halo to the Beo6, it looks like the Halo COULD be capable of displaying full color album cover art.
beojeff: Carolpa: chucky:Did anyone get colors on the Halo? I remember seeing it somewhere, maybe Khimo can make some fonds?There are coloured dots on the Halo if it is set for Beovision 11, Harmony,........... representing the coloured keys of a BR1. I'm wondering if B&O might have another surprise for us down the road. Comparing the screen size and resolution specs of the Halo to the Beo6, it looks like the Halo COULD be capable of displaying full color album cover art.
So same idea!
