Beosound Core “integrated setup” option?
This post has 10 Replies | 2 Followers
PhilLondon
London
Posts 3,637
PhilLondon Posted: Sun, Dec 26 2021 11:05 AM
Hi all!
I’m discovering my new Beosound core..
I’m couldn’t figure out what does this “integrated setup” feature do…
It’s hidden in the Product Settings > Configure > Settings > BeoLink > Link to other products
Any hint appreciated!
Beoworld app with direct photo upload and emoticons.
chucky
Posts 331
chucky replied on Sun, Dec 26 2021 11:17 AM
It integrates with a beovision when you have your speakers connected to your tv
When you choose this you only see the sources of the core and the beovision in the app.
chucky
Posts 331
chucky replied on Sun, Dec 26 2021 11:18 AM
One picure…. Big Smile says more then 100 words look at this setup in my little girls room
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 26 2021 12:22 PM
Or the ML sources if a BLC is integrated
PhilLondon
London
Posts 3,637
PhilLondon replied on Sun, Dec 26 2021 12:51 PM
Thank you! 🙏
lawrencejmcook
Posts 742
Carolpa:
Carolina, just to make sure I understand, in the first picture the BS Core is integrated to the BeoPlay V1, and in the second picture the BLC NL/ML is integrated to a BS Core, correct?
If so, for the second pic, in which product do you tick the INTEGRATED check box? The BLC or the Core?
I assume that the speakers (i.e. the Shape) are attached to the Core.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 26 2021 3:34 PM
lawrencejmcook:
Correct, in my case the Core is part of a Shape.
lawrencejmcook:
the Core
Note: in the BLC the "Connect to" both (primary and secondary) are set to BS9000 BLC (thus the Beolink Converter NL/ML)
Edit: the BLC is set as ASlave
lawrencejmcook
Posts 742
Fascinating. Thank you, Carolpa. I still have a lot to learn about the BLC NL/ML.
After that… the BLGW [:\'(]
Tim84
Munich
Posts 98
Tim84 replied on Sun, Dec 26 2021 6:24 PM
I habe a similar question. Perhaps someone can help.
I warnt my BeoVision to be activated automaticly if i AirPlay to my Core. Is this possible with integrated Setup? When I choose integrated setup Max beovision won‘t activate the picture when I select DTV. What am I doing wrong?
My setup is the following
BeoSound Core (with turbtable) and BeoVision 7 with BLC NL/ML Converter. The BLC NL/ML Converter is set up as A. Master.
thanks for your help
p.s. Anyone else has Problems with TuneIn since  yesterday?
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000
Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + Turntable
Kitchen: BeoPlay M3
Bathroom: Gira Radio + BeoLab Celestial
Entrance: BeoPlay M3
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 26 2021 7:03 PM
Tim84:
Leider nicht möglich mit "integrated setup". Das ist wohl möglich mit eine BV11, V1, Horizon, Avant.
Mit eine BLGW oder BLI wäre das wahrseinlich programierbar.
Sorry, not possible. With a BV11, V1, Horizon, Avant it would be available
Presumably with a BLGW or BLI it would be programmable.
Bw789
Posts 74
Bw789 replied on Sun, Dec 26 2021 7:27 PM
I wish the Beosound Stage had this option!
Page 1 of 1 (11 items) | RSS
