Beogram 1203 / 5239 Relay
Vowles
Posts 5
Vowles Posted: Sun, Dec 26 2021 1:45 PM
Hi there,
I am a very proud new owner of a Beogram 1203, however I have isolated that the relay switch in the player is not working and the broken wire is likely deep in the winding. Is is at all possible to find a replacement relay switch or are they near impossible to find?
If anyone has any information not these or even one lying around I would be hugely appreciative.
Details of the relay are: SPEC V2/M/90R V11 (orange paper casing). I can't seem to upload a photo but it is contained in the clear box on the underside of the player.
Thank you very much and hop everyone had a great Christmas!
Mark
San Francisco
Posts 107
Mark replied on Mon, Dec 27 2021 9:44 PM
It’s highly unlikely that you will find a replacement unless to find another 1200 series to cannibalize. Your best bet would may be to rewind the coil.
square4
Posts 241
square4 replied on Tue, Dec 28 2021 4:30 AM
Where are you located?
Henrik
Mark
San Francisco
Posts 107
Mark replied on Tue, Dec 28 2021 5:07 PM
San Francisco. Why do you ask?
square4
Posts 241
square4 replied on Tue, Dec 28 2021 5:26 PM
Oh,i it was vowles I ment.
Vowles
Posts 5
Vowles replied on Tue, Dec 28 2021 6:21 PM
I thought that might be the case. Have unwound it a little bit but not found the break yet. I think I will keep going with it and keep checking eBay for parts in the meantime. Thanks for the help.
I'm based in the UK as well!
square4
Posts 241
square4 replied on Thu, Dec 30 2021 6:40 AM
Hi Vowles.
I have the coil you`re looking for,i can not guarantee that it will work,but you can get it for free,you only have to pay for shipping
Send me a pm if you are interested.
Henrik.
Page 1 of 1 (7 items) | RSS
