Beogram 8002 - Almost there, just need a little help
This post has 1 Reply | 0 Followers
Brice
Posts 2
Brice Posted: Sun, Dec 26 2021 8:45 PM
Beogram 8002. Recapped the main pcb and the sub boards. The 47uf cap replaced in the microprocessor box.I have been over this board under magnification and corrected all that I have seen.
Here's what it will (and will not) do:
Press turn- it spins
Speed select, is does this fine
Press play- the table spins up, tonearm comes out some but not near the record edge.
Press right and left - it will do this
Press stop- this only works after you press turn. If you try to stop from "play" it does nothing.
Tonearm will not lower.
I beleive I am close on this but at this point I am stumped.
Please, advice needed.
Brice
Posts 2
Brice replied on Mon, Dec 27 2021 8:49 PM
Update: I opened the LDC and found a spiderweb on the one section. Cleaned this out and now when you push play the arm goes all the way to the center of the record (doesn't drop). If I move the arm back slightly and press play the arm will drop and will play for about a minute before lifting and returning to home.
The other change from before is now 33.33 reads 99.99 and 45 reads 55.00
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
