I have a BM2200 which works really well and sounds very good indeed. The only problem with it is that when i press Tape i get a crackle sometimes and sound doesn't come through the left speaker, if i then press the button in and out a couple of times it is fine. This doesn't happen on any of the other sources so I suspect it is dust in the switch.
Is there a way of cleaning the switch with deoxit without taking the machine apart? by that I mean can i remove the top of the switch and spray a small amount of deoxit in or will that just mess everything up?
Any help much appreciated as taking it apart looks like a bit of a nightmare and it's working find apart from teh Tape input.
The pushbutton tops are glued to the switch stems underneath.You could be lucky and get it off in one piece - but I will not be the one encouraging you to try.Much safer to losen and tilt the front panel.
