BeoSound Level incorrectly reports that mic is off
lawrencejmcook
Posts 742
lawrencejmcook Posted: Mon, Jan 3 2022 9:25 PM
Hi folks - I’m flagging an issue I experienced today and the fix.
While the BeoSound Level was connected to the mains I tried to re-run room compensation from the B&O app.
The app reported that the mic was turned off, so I flicked the mic switch and tried again.
Once more the app reported that the mic was switched off. This time I visually checked the switch position and it was definitely on.
I tried again in both positions, and regardless of position the app reported that the mic was off.
Rebooting the Level from the app made no difference.
A factory reset corrected the issue, and room compensation measurement ran to completion.
Note: I haven’t tested whether I can RE-RUN compensation.
Edmabu
Posts 13
Edmabu replied on Mon, Jan 3 2022 11:08 PM
Hi , it happened to me 3 or 4 times but no more and everything ok since 15-20 days
Page 1 of 1 (2 items) | RSS
