My beloved BV7-40 Mk 2 is still going strong, even though relegated to a secondary room after getting an Eclipse.
Now that I enjoy 4k and Bluray on the Eclipse, I wonder if it is possible to upgrade my DVD player on the 7-40 to a Bluray, perhaps taking advantage of older models to collect parts cheaply. I'm ok to to do work myself and I have some technical manuals as well.
What I need to know is - is it possible, and if so what parts/model numbers etc I should look for. Thank you
BV6-26, BV7-40, BL7.4, BL3, BL5, BS9000, BC1, ES1, Beo4, BeoPort
Although a very old thread, the first post here suggests that only Mk3 and after can be upgraded: https://archivedarchivedforum2.beoworld.org/forums/t/25266.aspx
A stand alone Blu ray player may be a better option.
Guy:Although a very old thread, the first post here suggests that only Mk3 and after can be upgraded: https://archivedarchivedforum2.beoworld.org/forums/t/25266.aspx A stand alone Blu ray player may be a better option.
