beogram 3500 turntable
This post has 10 Replies | 1 Follower
nightcountry
Posts 9
nightcountry Posted: Mon, Jan 10 2022 1:02 PM
Hello
Have a beogram 3500 turntable and for some reason when I begin to play a record it plays for approx 30 sec and then the tonearm disengages and the TT turns off. This happens if I begin to play the record anywhere on the lp not just the beginning. Have rebooted the unit, cleaned the stylus but am not sure how to solve the problem. Any suggestions would be appreciated. Thanks in advance
Mark
San Francisco
Posts 107
Mark replied on Mon, Jan 10 2022 7:46 PM
I do not have experience with the 3500; however, have you tried playing the record without the DIN cable connected? Did it behave the same?
nightcountry
Posts 9
I have not, however I just tried it and unfortunately the results were the same.
Mark
San Francisco
Posts 107
Mark replied on Tue, Jan 11 2022 7:06 AM
I would also test whether simply having it manually cued down without the platter results in the same stop action. It should not move inward. If so that re-enforces the below steps. If it does move by itself then I would look at the photo sensing adjustment as it may be set to behave as it does in the run-out groove versus the play area.  If by disengaging, you mean the tonearm raises and returns to its rest position, then its time to look at the larger electrolytic caps (C3 on the power supply and C3 on the main board for replacement) You also should clean connectors from to the main board and carefully inspect solder connections to reflow around the main control ICI.
nightcountry
Posts 9
It actually is getting worse. The tonearm will not even drop now. Manually cueing down makes no difference. When I hit play, the platter turns, the 33/45 light turns on on the tonearm but it will not drop. It turns off after 6 seconds. Curious about how you would adjust the photo sensing adjustment. When I push the forward < button the same thing happens but not when I push go back>
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jan 11 2022 3:43 PM
And you have a record on the platter?
And no anti-static mats or other "junk"?
Mark
San Francisco
Posts 107
Mark replied on Tue, Jan 11 2022 5:03 PM
You are missing details in your description. With a record on and pressing play does the tonearm move to the edge of the record and not drop or does it not move at all?  Without a record does the arm move to the center and simply come back to the stop position or not move at all?
nightcountry
Posts 9
I have a record on the platter. No junk.
nightcountry
Posts 9
Hi Mark
With a record on and then pressing play, the tonearm does not move and does not drop. With no record on, the same thing happens. No movement at all except the platter turns on for a few seconds and then stops.
Mark
San Francisco
Posts 107
Mark replied on Tue, Jan 11 2022 6:21 PM
I am afraid it needs a tech at this point.
nightcountry
Posts 9
Thanks for your help
Page 1 of 1 (11 items) | RSS
