Beolab 5 Disk Turn
This post has 5 Replies | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Tue, Jan 11 2022 5:10 PM
Hello all
Can anyone explain how to turn the large disk on a lab 5 180 degrees clockwise (or anti clockwise Big Smile )
One of my disks has a little knock on it for years and actually turning it round so its at the back would make it no longer visible and save a few hundred quid.
Are any special tools needed or is there a process to follow to do this?
cheers
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Mr 10Percent
So West, Its Now East
Posts 591
They are glued in place. Seriously glued I believe?
B&O use a silicone-type adhesive between the aluminium disc and the cast Under-disc.
there is a YT video somewhere showing it being assembled.
I would imagine removing the disc would involve destroying it first?
Mr 10Percent
Posts 591
https://youtu.be/VCl1DIcB_3w
0:29min. Lower disc assembly and after that, the dosing of silicone adhesive on to the lower disc body.
it would be very fortunate if you did dissemble the ALT structures and that lower disc could be rotated, but then you would be a braver man than I.
Mr 10Percent
Posts 591
*** Link removed ***
Mr 10Percent
Posts 591
It’s directional to lock down the lower lens assembly 9008 - so not an option unless you buy a new disc cover
Seanie_230
UK
Posts 2,278
Yeah I found this out that even if I could get it off they are installed one way only.
Oh well replacement it is Big Smile
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (6 items) | RSS
