At one B&O sale-shop in sweden it says that the Beosound Core is discontinued. Is this right?
Have someone heard anything about this?
Best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
I haven’t heard anything about this.
However, that would mean that there must be something else to replace it - it is needed for the BS Shape!
Martin: At one B&O sale-shop in sweden it says that the Beosound Core is discontinued. Is this right?
Just checked... I cannot see anything saying that.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Wasn’t the Core updated at some point and subsequently given a new Part Number? I seem to remember reading that the Core underwent some minor hardware changes which warranted a new P/N. Could just be the old P/N having been declared as “Discontinued?”
B&O did an price increase on the Core, from 800 to 900€. I think they don’t do that on an discontinued product.
Core was updated at some point with a different part number to include the ability to use an IR eye. That's it. Otherwise, unchanged throughout its life, as far as I understand.
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Maybe Mozart compatible? But now that Multiroom and Mozart can play nicely, I'm not sure why a big change would be required.
What other changes might they make to Core? :)
Curly:Maybe Mozart compatible? But now that Multiroom and Mozart can play nicely, I'm not sure why a big change would be required.
Curly:Maybe Mozart compatible? But now that Multiroom and Mozart can play nicely, I'm not sure why a big change would be required. What other changes might they make to Core? :) Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote Previously: BeoSound 1 non-GVA
