Beovox S45-2 precaution!
Rune8600
Posts 2
Rune8600 Posted: Fri, Jan 14 2022 10:51 AM
Hi forum.
I bought a pair of S45-2 new in 1980, and now I want to put them to good use again after they were standing in the loft.
I read that there's a risk that some old glue will fail, causing the magnet to drop, and thereby bending/damaging the voicecoil.
What could/should I do to prevent this?
NOTE: I'm not able to tick the Question option above.
Kind regards,
Rune
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig replied on Fri, Jan 14 2022 11:44 AM
Hi
I would be tempted to try them out first, then maybe look at this thread for some inspiration ;¬)
Craig
Keiths Woofers - (beoworld.org)
matador43
Posts 1,373
matador43 replied on Fri, Jan 14 2022 12:04 PM
Rune8600:
https://archivedforum2.beoworld.org/forums/p/47445/340071.aspx#340071
Rune8600
Posts 2
Rune8600 replied on Sun, Jan 16 2022 11:15 AM
Thanks a lot to both of you - I will now take out the woofers, clean the area where the epoxy will be, and apply the latter.
Page 1 of 1 (4 items) | RSS
