Beovision Eclipse 65 mk1 Stand No Longer Detecting
This post has 12 Replies | 1 Follower
mobilett
Posts 39
mobilett Posted: Mon, Jan 24 2022 3:13 AM
Hello I'm looking for help with my Stand. The stand is not detecting nor showing.
Under menu Service System Voltages, it shows as 12V == 0.03V
Can someone please let me know what that means?
When the stand worked, it was quite jerky and not very smooth.
Also, periodically, the green light will flash rapidly while turned off. All connections are fine. I've tried unplugging for hours, but it has not helped.
Thank you.
Beouser66
Posts 47
Beouser66 replied on Mon, Jan 24 2022 8:15 AM
you need to contact a b&o serviceguy to change dsse board in soundcenter
mobilett
Posts 39
mobilett replied on Tue, Jan 25 2022 6:24 AM
Thanks, do you know the approximate cost?
tIRED
Posts 9
tIRED replied on Fri, Jan 28 2022 10:20 PM
Mine just did the same! I have the 55" though..
Did you find anything out about the cost? Or did you perhaps find another solution?
mobilett
Posts 39
mobilett replied on Sun, Jan 30 2022 2:28 AM
tIRED:
No I didn't get a cost yet, or parts availability. I reached out to the dealer and am awaiting a response. Please do post if you get any information.
mobilett
Posts 39
Update, I've contacted a few different b&o repairmen and am awaiting a quote for the DSSE board.
Has anyone else purchased one of these and swapped them to fix their stand issue?
mobilett
Posts 39
mobilett replied on Fri, Feb 11 2022 12:47 AM
Beouser66:
I heard from the b&o service that there is no DSSE board in the beovision eclipse 65 mk1 (based off the serial number).  He wasn't sure what would cause the stand to stop detecting and the 12V == 0.03V.
Do you have any other suggestions?
Many thanks
Beouser66
Posts 47
Beouser66 replied on Fri, Feb 11 2022 4:32 PM
Hi
of cource is a dsse board in soundcenter
that is the board in soundcenter both mk1 and mk2
that all hdmi connectors ,pl connectors puc and stand connectors
are mounted, are that reely a b&o servicepartner??
if so this is a known issue and i don’t belive
they know about it,
and for clarify the module is in soundcenter
NOT in LG screen
Beouser66
Posts 47
Beouser66 replied on Fri, Feb 11 2022 4:38 PM
Hi again
but wy do you not contact the servicepartner
and tell that your stand doesnt work, and let them
investigate the problem (i am 99%) shure that the
thing they then change is the dsse board if you
get this message 12v missing
mobilett
Posts 39
mobilett replied on Fri, Feb 11 2022 4:53 PM
Beouser66:
Hi
they know about it,
NOT in LG screen
Thanks, I'll ask them again. Yes they are a service centre. Unfortunately they are about 4,000 kms away. None of the nearby service centres have answered the phone in the last 3 weeks, or responded to emails.
Beouser66
Posts 47
Beouser66 replied on Sat, Feb 12 2022 9:52 AM
Suggest you contact b&o denmark thru
customer service, and ask how to get help, have you contact the store you bought it from?
the store are responsible to act to solve this matter
Seanie_230
UK
Posts 2,278
Hello
Don’t know if it’s worth mentioning if you can get a board it’s easy to change.
I saw the engineer remote speaker cover, then the plastic cover on the left. About five screws and a few ribbon cables and the board comes out.
Took a total of about 15 mins
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mobilett
Posts 39
mobilett replied on Wed, Feb 23 2022 5:20 AM
Thanks for all the help everyone.
The dealer asked me to disassemble the TV and bring back the sound centre and stand, so I did that. It's now at the dealer and the technician is going to repair it this week. I wish they would have just come over and swapped that board considering everyone says it's so quick and easy. Anyway, will post the results and the exact cause when I get it back. I miss my eclipse already!
Page 1 of 1 (13 items) | RSS
