Adding to the information already provided by Lawrence.
In the service manual you find this information:
"Switch for loudspeaker position
Free, Wall or Corner
Input sensitivity
Adjustable by three position switch
Corresponding to 83 dB, 88 dB or 91 dB for main speakers"
Setting 1 = BL1 = targeting 91db = it will play louder compared to setting 2 or 3.
Thank you both. I didn’t think to look in the service manual, and the user manual doesn’t really address the question. I assumed that the ‘setting’ switch controlled the crossover frequency; I stand corrected.
Yeah.... When I got mine and wanted to use it with a non-B&O AV receiver I didn't find the information I wanted in the user manual either. Thought the switch would affect cross over as well.
Read in a different post it is fixed around 90hz.
How did you connect the BL2 to the shape?
- Beovision Eclipse 55 Mk2 - Beolab 19 - Beosound Shape - Oppo UDP-203
swestland: How did you connect the BL2 to the shape?
