Shape + BL 2 — subwoofer settings?
This post has 6 Replies | 2 Followers
BeoFrederic
Posts 276
BeoFrederic Posted: Mon, Jan 24 2022 8:34 PM
I have a 4-speaker Shape and a BL 2 attached. I’ve been fiddling with the switches on the sub. Does anyone know what B&O recommends for the ‘Setting’ switch? Position 1, 2, or 3?
lawrencejmcook
Posts 742
Hi Frederic,
It changes the output level of the BL2.
Setting 1 was for BeoLab 1, and setting 3 was for BeoLab 2500. Setting 2 was for everything (contemporaneous) in between.
Lawrence
Ravsted
Denmark
Posts 345
Ravsted replied on Mon, Jan 24 2022 10:12 PM
Adding to the information already provided by Lawrence.
In the service manual you find this information:
"Switch for loudspeaker position
Free, Wall or Corner
Input sensitivity
Adjustable by three position switch
Corresponding to 83 dB, 88 dB or 91 dB for main speakers"
Setting 1 = BL1 = targeting 91db = it will play louder compared to setting 2 or 3.
BeoFrederic
Posts 276
Thank you both.  I didn’t think to look in the service manual, and the user manual doesn’t really address the question.  I assumed that the ‘setting’ switch controlled the crossover frequency; I stand corrected.Smile
Ravsted
Denmark
Posts 345
Ravsted replied on Mon, Jan 24 2022 10:30 PM
Yeah.... When I got mine and wanted to use it with a non-B&O AV receiver I didn't find the information I wanted in the user manual either. Thought the switch would affect cross over as well.
Read in a different post it is fixed around 90hz.
swestland
Netherlands
Posts 73
swestland replied on Tue, Jan 25 2022 7:36 PM
How did you connect the BL2 to the shape?
- Beovision Eclipse 55 Mk2 - Beolab 19 - Beosound Shape - Oppo UDP-203
BeoFrederic
Posts 276
swestland:
Powerlink RJ-45 out of the Core, into PL jack in BL2.  Cable from Steve @ Sounds Heavenly.  I didn't run a loop back from the BL2 to the Shape.  Received conflicting advice about this.  I went the simplest route.
Page 1 of 1 (7 items) | RSS
