Not able to update BV11
This post has 6 Replies | 0 Followers
Skaler
Posts 4
Skaler Posted: Mon, Jan 24 2022 9:01 PM
Hi, I’m trying to update my bv11. The software-version is 0.0.0.0. I have connected it to wifi, and it says connected. When I try to update via internet, i got a message that reads «error contacting the internet service» I have tried using cable and iphonesharing. I got the same message. Any ideas?
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jan 25 2022 9:28 AM
Have you had a software version stated before?
Can you try a factory reset?
Skaler
Posts 4
Skaler replied on Tue, Jan 25 2022 10:06 AM
I have tried factory-reset, but I dont know if there have been another software on it.
Aussie Michael
Melbourne, AU
Posts 3,730
When you tried a factory reset did you do it by changing the location to a different country first then back?
I found that this was the mode to reset the TV properly.
The BV-11 and the Avant are the same Video Engine / Chassis generation.
Skaler
Posts 4
Skaler replied on Tue, Jan 25 2022 4:13 PM
Thanks, tried to change it to another and back, same error both times.
Millemissen
Flensborg, Denmark
Posts 14,680
In that case, please try contacting support or your dealer - you should be able to get the latest sw to install from a USB stick.
Skaler
Posts 4
Skaler replied on Wed, Jan 26 2022 5:47 AM
B&O already sent it to me, but the TV cant find it. Is it correct that it should be a .bin-file? Am I supposed to format the USB in fat-32 and and put this file with bin-ending on the usb, without any folder-structure?
Page 1 of 1 (7 items) | RSS
