Hi, I’m trying to update my bv11. The software-version is 0.0.0.0. I have connected it to wifi, and it says connected. When I try to update via internet, i got a message that reads «error contacting the internet service» I have tried using cable and iphonesharing. I got the same message. Any ideas?
Have you had a software version stated before?
Can you try a factory reset?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I have tried factory-reset, but I dont know if there have been another software on it.
Thanks, tried to change it to another and back, same error both times.
In that case, please try contacting support or your dealer - you should be able to get the latest sw to install from a USB stick.
B&O already sent it to me, but the TV cant find it. Is it correct that it should be a .bin-file? Am I supposed to format the USB in fat-32 and and put this file with bin-ending on the usb, without any folder-structure?
