Hello,
One of my bv 11 46 failed to update the software and the Puc, since I bought it I never tried to update it.
It just says Failed verification. It is connected by wlan. May be it needs to be connected by LAN.
Do you know how to make a hard reset ? Maybe it could solve this issue.
thanks
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Hello
I have both. For this one.I usually take a beo4 with joystick on the center.
In the setup menu , I have just found language and change it for the same (nothing happened).
