Hard reset on a beovision 11 46
olvisab
Posts 1,391
olvisab Posted: Sun, Jan 30 2022 6:56 PM
Hello,
One of my bv 11 46 failed to update the software and the Puc, since I bought it I never tried to update it.
It just says Failed verification. It is connected by wlan. May be it needs to be connected by LAN.
Do you know how to make a hard reset ? Maybe it could solve this issue.
thanks
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Aussie Michael
Melbourne, AU
Posts 3,730
I think it might depend on if you have the model with the beo4 or the beo remote one.
As the 11 with the BR1 is the same chassis as the Avant Gen 1 what I had to do on that is change the country to another (same) to do a hard reset
olvisab
Posts 1,391
olvisab replied on Mon, Jan 31 2022 12:32 PM
Hello
I have both. For this one.I usually take  a beo4 with joystick on the center.
In the setup menu , I have just found language and change it for the same (nothing happened).
Page 1 of 1 (3 items) | RSS
