Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I have also used the A1 (first gen) stereo paired in various places on the go. For the size and price they sound extremely well. If you place the A1 on a strategic spot near a wall or in a corner the performance is even greater. Line of sight was a must and max distance between the two A1’s rather limited.P6 was even better in stereo, two extra drivers then compared a set of A1’s and a lot more body. You can upgrade to those as well !
what would be cool if B&O makes some kind of bluetooth hub/router so you can use let’s say 10 different A1’s /P6 ‘s wireless for a super funky mobile cinema experience.
