Stereo pair the A1’s to a £30 Bluetooth transmitter from Amazon with Line In.
Connect the line in on the BT transmitter to the BM5 and that should work as far as it can
Since you don't mention a line-in, I assume you have the A1 mk2s. AFAIK, the USB on the A1 mk2s requires a digital input so it it takes more than a pass through cable as you suggest. Not sure, but I would definitely drop SoundsHeavenly a line.
Stan:Since you don't mention a line-in, I assume you have the A1 mk2s. AFAIK, the USB on the A1 mk2s requires a digital input so it it takes more than a pass through cable as you suggest. Not sure, but I would definitely drop SoundsHeavenly a line.
Hi Razlaw,
Unfortunately the 2nd gen A1s don't have a Line input, so I can't make a cable for those, but the 1st gen version can be easily stereo paired via a cable. The other option (as mentioned above) is to add a Bluetooth transmitter and cable that to the Beosound so that you don't need to keep re-pairing the speakers. I can help with that cable if required!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Steve at Sounds Heavenly:Hi Razlaw, Unfortunately the 2nd gen A1s don't have a Line input, so I can't make a cable for those, but the 1st gen version can be easily stereo paired via a cable. The other option (as mentioned above) is to add a Bluetooth transmitter and cable that to the Beosound so that you don't need to keep re-pairing the speakers. I can help with that cable if required! Kind regards, Steve. Steve. www.soundsheavenly.com Founder of Sounds Heavenly Cables and Brand Ambassador for Bang & Olufsen Sounds Heavenly are proud to sponsor BeoWorld!
No problem, you just need to buy a Bluetooth transmitter (sorry I don't sell these) and connect it to the Beosound 5 with a cable (I DO sell these!). This lets you link to the A1 speakers wirelessly. Please feel free to get in touch tomorrow via my website when it re-opens and I can help further.
Steve at Sounds Heavenly:Hi, No problem, you just need to buy a Bluetooth transmitter (sorry I don't sell these) and connect it to the Beosound 5 with a cable (I DO sell these!). This lets you link to the A1 speakers wirelessly. Please feel free to get in touch tomorrow via my website when it re-opens and I can help further. Kind regards, Steve. Steve. www.soundsheavenly.com Founder of Sounds Heavenly Cables and Brand Ambassador for Bang & Olufsen Sounds Heavenly are proud to sponsor BeoWorld!
That is good news! I can provide a cable that splits the sound to send the correct sound to each speaker. Please feel free to get in touch via my sponsor link below when you are ready and I will be happy to help.
