I have a pair of BeoBox 3000 passive Loudspeakers, flat panel, type 6716 and a MCL 2P Amplifier.What I understand the BeoVox 3000 has 8 Ohms Impedance.I have a simple DVD-player with HDMI-connection.I have also a couple of Din Plug Scew Connect, Male.What do I need to play CD-music with this speakers? Do I need the MCL 2P Amplifier at all if the is some other solution? mean, do I need to buy a MCL 2AV to make it work? Or a new stereo system without any speakers which can run passive speakers?Sincerely,Esa Nyberg
Already answered in your other post.
In addition to that:
If you use a Beomaster with an amp built in (e.g. a beomaster 4500), you will not need the 2P.
Just connect DVD player (R/L output) to the Beomaster and also the speakers.
Thank you for your answer.I will consider your suggestion.Sincerely,Esa Nyberg
Thanks a lot for your answer.I'll consider that.Sincerely,Esa Nyberg
