Connect BeoVox 3000 with any CD-player with HDMI-connection - How?
EN
Sweden
Posts 7
EN Posted: Tue, Feb 8 2022 10:53 PM
I have a pair of BeoBox 3000 passive Loudspeakers, flat panel, type 6716 and a MCL 2P Amplifier.
What I understand the BeoVox 3000 has 8 Ohms Impedance.
I have a simple DVD-player with HDMI-connection.
I have also a couple of Din Plug Scew Connect, Male.
What do I need to play CD-music with this speakers?
Do I need the MCL 2P Amplifier at all if the is some other solution? mean, do I need to buy a MCL 2AV to make it work? Or a new stereo system without any speakers which can run passive speakers?
Sincerely,
Esa Nyberg
Millemissen
Flensborg, Denmark
Posts 14,680
Already answered in your other post.
Millemissen
Flensborg, Denmark
Posts 14,680
In addition to that:
If you use a Beomaster with an amp built in (e.g. a beomaster 4500), you will not need the 2P.
Just connect DVD player (R/L output) to the Beomaster and also the speakers.
EN
Sweden
Posts 7
EN replied on Wed, Feb 9 2022 2:56 PM
Thank you for your answer.
I will consider your suggestion.
Sincerely,
Esa NybergSmile
EN
Sweden
Posts 7
EN replied on Wed, Feb 9 2022 2:58 PM
Thanks a lot for your answer.
I'll consider that.
Sincerely,
Esa Nyberg Smile
Page 1 of 1 (5 items) | RSS
