BeoVision 10 + Beoremote One + Apple TV 4K
This post has 10 Replies | 0 Followers
Majomi
Copenhagen
Posts 9
Majomi Posted: Sat, Feb 12 2022 1:21 PM
Hi beoworld,
I’ve successfully connected a new beoremote one BT with my beovision and Apple tv. I can switch to ‘Beo4 Video’ and then have full control over my beovision, and then switch to ‘Apple tv’ and have full control over my Apple tv… however, when I’m controlling the Apple TV and want to adjust the volume i have to switch back to ‘Beo4 Video’ just to adjust volume, and then back to ‘Apple tv’ to control movies etc… is there a way to simplify this, so I don’t have to do all the switching back and forth?
Thank you
beojeff
USA
Posts 2,012
beojeff replied on Sat, Feb 12 2022 1:37 PM
Did you check to see if the Apple Remote is in your PUC list? If not, you might need to have a dealer add it to your PUC list. This give you control of your Apple TV via an IR blaster connected to your BV10. This way, you don't need to change the device controlled by your BeoRemote One.
beojeff
USA
Posts 2,012
beojeff replied on Sat, Feb 12 2022 1:39 PM
If you're not familiar with PUC, I should add that the PUC control is setup on your BeoVision 10 with regard to each video input connection.
beojeff
USA
Posts 2,012
beojeff replied on Sat, Feb 12 2022 1:41 PM
Also, if the Apple Remote is NOT listed in the BV10 PUC list, you can actually use another device that's listed in the PUC list and then program your Apple TV to accept those remote codes.
Millemissen
Flensborg, Denmark
Posts 14,680
beojeff:
This already was discussed here:
https://archivedforum2.beoworld.org/forums/p/50349/353488.aspx#353488
The ‘short’ answer to the question is……….if Majomi wants to do it right (meaning: ease of use and option for turning on the ATV/BV10 for just music in one go), he should have the Apple PUC installed and best use the remote, that was made for that BV = a Beo4.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Feb 12 2022 2:19 PM
Millemissen:
If the PUC is installed the control of the ATV will also be fine with a BR1 (similar experience as a Beo4).
Majomi
Copenhagen
Posts 9
Majomi replied on Sat, Feb 12 2022 2:40 PM
Alright, I’ll go and talk to my local dealer… thank you!
beojeff
USA
Posts 2,012
beojeff replied on Sat, Feb 12 2022 2:54 PM
Majomi:
In the meantime, you can use another device in the PUC and have the Apple TV learn the remote codes. (A previous post I made about this went into moderation.)
Millemissen
Flensborg, Denmark
Posts 14,680
Carolpa:
Millemissen:
Sure that is possible.
However, if one often wants to listen to music only via Airplay (with a blank screen and only from the external L/R speakers), that will be much easier with a Beo4……….using the A/V function - the A/V button (either as hard button or as a List button moved to one of the first places in the list), before pushing the actual source button.
That won’t be that easy with the Beoremote One/BT.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Feb 12 2022 4:24 PM
Millemissen:
Carolpa:
Millemissen:
"picture off" should do the trick also. The AV is often a listed item on several Beo4's, so hardly a difference.
Millemissen
Flensborg, Denmark
Posts 14,680
On further thinking……
…..one of the Mybuttons could be used for this purpose for easy access to a function like A/V -> ‘Source’ (in order to have a blank screen right away).
So either one goes…….I just love the Beo4’s, when it comes to controlling the older BV’s Smile
Page 1 of 1 (11 items) | RSS
