Apple TV and BeoMaster 5
This post has 7 Replies | 2 Followers
Griebel
Posts 416
Griebel Posted: Mon, Mar 4 2013 7:31 AM
Quick question. Thought I would find it easily on this forum, nut no.
Can I access the music files on a BeoMaster 5 via an Apple TV, which is on the same network?
Heribert
Vorarlberg / Austria
Posts 804
As far as I know the ATV (if in original condition) always needs iTunes and so it should work if you have iTunes running on you BM5.
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Griebel
Posts 416
Griebel replied on Mon, Mar 4 2013 9:16 PM
Indeed. Well it's worth trying.
lano
Posts 161
lano replied on Thu, Mar 7 2013 6:37 PM
Hi, did you try to install iTunes on the Beomaster5? If so, how did it work?
Griebel
Posts 416
Griebel replied on Thu, Mar 7 2013 8:07 PM
No yet. Will do this weekend.
Was also waiting for potential feedback from other forum members in case they had tried it.
Keep you posted.
Griebel
Posts 416
Griebel replied on Fri, Mar 8 2013 8:11 PM
Confirm that it works. By installing iTunes on the BM5 its possible to access its media files from an Apple TV.
The only little issue is that if you reboot the BM5, you'll have to relaunch iTunes via the Service Menu. Wondering if there is a way iTunes starts automatically upon reboot.
lano
Posts 161
lano replied on Mon, Mar 11 2013 10:22 PM
Yes, there is. You can add a record to the registry to launch an Application at start-up. I have done that for the Beosound5.exe and B&O has done this also with the temp monitor software.
The key should be added under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
You can google for examples or look at the tempmon that B&O has set up. Let me know if you run into problems.
Griebel
Posts 416
Griebel replied on Tue, Mar 12 2013 6:12 AM
Yes, thanks. It now works fine.
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
