B&O 4002 tonearm damper lubrication
buisson
Posts 15
buisson Posted: Tue, Mar 5 2013 12:21 PM
A question about these brass tonearm dampers on the 4002 : do they need lubrication or not ? (I mean  : the inside of the cylinder and the piston). Were they lubricated when new ? I just bought a new one which shows no sign of lubrication, but works properly; is there a risk of wear if it works without lube ?
Thank you for you answers.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Mar 5 2013 12:38 PM
I don't think any lubricants were added in production.
My experience, and what I have had best success with, is that if the piston/cylinder functions corrrectly without lubrication, I let it run like that.
If the piston/cylinder shows signs of wear it may be necessary to add a little oil to tighten the seal around the piston.
Just a thin film of acid-free oil (sewing machine oil). Put a drop on your little finger and smear it around the inside of the cylinder.
Work the piston a couple of times manually and adjust the air screw on top of the cylinder head for a suitable damping delay.
Page 1 of 1 (2 items) | RSS
