Linking Beosystem 7000 to Aavant 32 RF
This post has 7 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Sat, Mar 16 2013 10:51 AM
Dear members,
I'm sorry for asking another question. I've just tried to link my Beosystem 7000 to my Avant 32 RF. I've used a 1610 converter (Audiokit AV 9000) but the connection doesn't seem to work. Do I need another converter? What can be wrong?
Thanks very much.
Rgds,
Kai
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Mar 16 2013 10:59 AM
You need the 1611. Works fine - I had this set up for many years. They are about to stop production of the 1611/1610 so if you want a new one, now is your last chance!
Peter
Manbearpig
Posts 908
Manbearpig replied on Sat, Mar 16 2013 12:07 PM
Thanks Peter. New one is too expensive. Bang und Olufsen wanted 80 Euro for a used one. Is that reasonable?
Rgds,
Kai
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Mar 16 2013 12:23 PM
Anything with two digits from B&O is a bargain Erm..
It's not going to wear in use, so if you feel the solution is worth that to you, it's a decent price for having one without a need to hunt around. They aren't exactly given away in online auctions either, unless it happens to be included in a bigger lot.
--mika
Manbearpig
Posts 908
Ok. I'll try grabbing it. By the way: without having had a listen yet, most functions of the Beosystem 7000 seem to be working. However, it does seem to me that the Beogram 7000 CD opens on its own from time to time. Is that a common issue? What may be the cause? Does anybody still have the brush to clean the needle of the Beogram record player?
Rgds,
Kai
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Mar 17 2013 6:23 PM
Manbearpig:
There's a microswitch in the tray mechanism that senses the end of travel. I guess this could be caused by it being dirty.
--mika
Manbearpig
Posts 908
Sounds like an easy fix but if you have to open the Beogram CD for cleaning purposes than it's probably not... ?
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Mar 17 2013 9:21 PM
Actually it is quite easy - even a complete ham fisted idiot like me can do this - and have done so! The top comes off very easily and the switch is obvious.
Peter
Page 1 of 1 (8 items) | RSS
