Beovision 4 data cable
11048437
Posts 71
11048437 Posted: Fri, Mar 22 2013 2:48 AM
Hi everyone,
I need some help please. My Beovision 4 was moved to another location and by mistake the Data cable( USB to RS232) was damaged. I wonder if someone could help me with the connections into the RS232.
I have 4 cable wires and I do not have any ideea where it goes into the RS232.
Any help will be highly appreciated!
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Very Warm Welcome to Beoworld..
I think the drawing below should help you repair your cable
Regards Keith....
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Mar 22 2013 9:35 AM
Basically it is a DB 9 null modem cable.
See HERE
Ralf
11048437
Posts 71
11048437 replied on Sun, Mar 24 2013 4:43 PM
Thank you for your help.
My cable has 4 wires. The diagram shows actually that only 3 cable are used. The +5V wire is not used at all?
thanks in advance for your help!
11048437
Posts 71
11048437 replied on Tue, Mar 26 2013 3:50 PM
Finally, I managed to remove the front screen and PowerON/OFF manually the screen as the Serial cable is not working at all!.
Now I have another problem: the image is zoomed at max ( I see only the top left of the image) and there is not any specs about Zoom in the manual.
Any ideea what IO should to to concerning the Zoom?
thanks in advance for help!
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Mar 26 2013 4:46 PM
There is a Beovision 4 cable for sale on ebay right now....
Page 1 of 1 (6 items) | RSS
